> For the complete documentation index, see [llms.txt](https://docs.n8n.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.n8n.io/integrations/builtin/trigger-nodes/n8n-nodes-base.seatabletrigger.md).
# SeaTable Trigger
Learn how to use the SeaTable Trigger node in n8n. Follow technical documentation to integrate SeaTable Trigger node into your workflows.
[SeaTable](https://seatable.com/) is a collaborative database application with a spreadsheet interface.
{% hint style="info" %}
**Credentials**
Refer to the [SeaTable credentials documentation](https://docs.n8n.io/integrations/builtin/credentials/seatable.md) for authentication information for this node.
{% endhint %}
**Examples and templates**
For usage examples and templates to help you get started, refer to n8n's [SeaTable Trigger integrations](https://n8n.io/integrations/seatable-trigger/) page.
{% endhint %}
