# Page Not Found
The URL `builtin/flow-control/split-in-batches` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Loop Over Items (Split in Batches)](https://docs.n8n.io/integrations/builtin/core-nodes/n8n-nodes-base.splitinbatches.md)
- [Bitbucket credentials](https://docs.n8n.io/integrations/builtin/credentials/bitbucket.md)
- [Hugging Face credentials](https://docs.n8n.io/integrations/builtin/credentials/huggingface.md)
- [LingvaNex credentials](https://docs.n8n.io/integrations/builtin/credentials/lingvanex.md)
- [APITemplate.io credentials](https://docs.n8n.io/integrations/builtin/credentials/apitemplateio.md)
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://docs.n8n.io/integrations/builtin/core-nodes/n8n-nodes-base.splitinbatches.md?ask=<question>&goal=<user_goal>
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/integrations/builtin/core-nodes/n8n-nodes-base.splitinbatches.md`).
