Data flow within nodes#
Nodes can process multiple items.
For example, if you set the Trello node to Create-Card, and create an expression that sets Name using a property called name-input-value from the incoming data, the node creates a card for each item, always choosing the name-input-value of the current item.
For example, this input will create two cards. One named test1 the other one named test2:
1 2 3 4 5 6 7 8  |  |
            This page was
