Reference previous nodes
When working with data in n8n, you'll often need to reference information from the current node or from previous nodes in your workflow.
Common ways of referencing
The most frequently used methods for accessing data are:
$json: Access JSON data from the current input item$('<node-name>').item.json: Access JSON data from a linked item in a previous node$('<node-name>').item.binary: Access binary data (files, images) from a linked item in a previous node
Other referencing methods
These methods work in both expressions and the Code node:
$binary
Access binary data from the current input item
$input.item
The input item currently being processed
$('<node-name>').first()
Get the first item from a specified node
$('<node-name>').last()
Get the last item from a specified node
$('<node-name>').all()
Get all items from a specified node
Current node input
Methods for working with the input of the current node. Some methods and variables aren't available in the Code node.
$binary
Shorthand for $input.item.binary. Incoming binary data from a node
$input.item
The input item of the current node that's being processed. Refer to Item linking for more information on paired items and item linking.
$input.all()
All input items in current node.
$input.first()
First input item in current node.
$input.last()
Last input item in current node.
$input.params
Object containing the query settings of the previous node. This includes data such as the operation it ran, result limits, and so on.
$json
Shorthand for $input.item.json. Incoming JSON data from a node. Refer to Data structure for information on item structure.
✅ (when running once for each item)
$input.context.noItemsLeft
Boolean. Only available when working with the Loop Over Items node. Provides information about what's happening in the node. Use this to determine whether the node is still processing items.
_input.item
_input.all()
_input.first()
_input.last()
_input.params
_json
Shorthand for _input.item.json. Incoming JSON data from a node. Refer to Data structure for information on item structure. Available when you set Mode to Run Once for Each Item.
_input.context.noItemsLeft
Output of other nodes
Methods for working with the output of other nodes. Some methods and variables aren't available in the Code node.
$("<node-name>").all(branchIndex?, runIndex?)
Returns all items from a given node. If branchIndex isn't given it will default to the output that connects node-name with the node where you use the expression or code.
$("<node-name>").first(branchIndex?, runIndex?)
The first item output by the given node. If branchIndex isn't given it will default to the output that connects node-name with the node where you use the expression or code.
$("<node-name>").last(branchIndex?, runIndex?)
The last item output by the given node. If branchIndex isn't given it will default to the output that connects node-name with the node where you use the expression or code.
$("<node-name>").item
The linked item. This is the item in the specified node used to produce the current item. Refer to Item linking for more information on item linking.
$("<node-name>").item.binary
Binary data from the linked item, keyed by binary property name (data by default). Refer to BinaryFile for the available properties.
$("<node-name>").params
Object containing the query settings of the given node. This includes data such as the operation it ran, result limits, and so on.
$("<node-name>").context
$("<node-name>").itemMatching(currentNodeInputIndex)
Use instead of $("<node-name>").item in the Code node if you need to trace back from an input item.
Reference binary data from a previous node
$('<node-name>').item returns the whole linked item, so you can read its binary data the same way you read its JSON data: use .item.json for the item's JSON object and .item.binary for its binary data (files, images, and other attachments).
An item can hold several binary properties, each under its own name, so .item.binary returns an object of those properties rather than a single value. Most nodes output binary data under the property name data, but the name depends on the upstream node. Each binary property is a BinaryFile with fields such as fileName, mimeType, and fileExtension.
For example, to get the file name of the binary property data produced by an HTTP Request node:
For more about binary data and the nodes that produce it, refer to Binary data.
Related resources
Last updated
Was this helpful?
