Skip to content
For the complete documentation index, see llms.txt. This page is also available as Markdown.
Preserving linking in the Code node
When referencing a previous node you need to know which item to use. This is solved by item linking. Most nodes automatically link every output item to an input item, creating a chain of items that you can work back along to access previous items. For a deeper conceptual overview of this topic, refer to Item linking concepts. This document focuses on practical usage examples.
When using the Code node, there are some scenarios where you need to manually supply item linking information if you want to be able to use $("<node-name>").item later in the workflow. All these scenarios only apply if you have more than one incoming item. n8n automatically handles item linking for single items.
These scenarios are when you:
  • Add new items: the new items aren't linked to any input.
  • Return new items.
  • Want to manually control the item linking.
n8n's automatic item linking handles the other scenarios.
To control item linking, set pairedItem when returning data. For example, to link to the item at index 0:
		"json": {
		// The index of the input item that generated this output item
		"pairedItem": 0
pairedItem usage example
Take this input data:
And use it to generate new items, containing just the name, along with a new piece of data:
newItems is an array of items with no pairedItem. This means there's no way to trace back from these items to the items used to generate them.
Add the pairedItem object:
Each new item now links to the item used to create it.
Last updated
Was this helpful?
