> For the complete documentation index, see [llms.txt](https://docs.n8n.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.n8n.io/build/work-with-data/reference-data/link-data-items/item-linking-for-node-creators.md).
# Item linking for node creators
{% hint style="info" %}
**Programmatic-style nodes only**
This guidance applies to programmatic-style nodes. If you're using declarative style, n8n handles paired items for you automatically.
{% endhint %}
Use n8n's item linking to access data from items that precede the current item. n8n needs to know which input item a given output item comes from. If this information is missing, expressions in other nodes may break. As a node developer, you must ensure any items returned by your node support this.
This applies to programmatic nodes (including trigger nodes). You don't need to consider item linking when building a declarative-style node. Refer to [Choose your node building approach](/connect/create-nodes/plan-your-node/choose-a-node-building-style.md) for more information on node styles.
Start by reading [Item linking concepts](/build/work-with-data/reference-data/link-data-items/how-items-link-through-workflows.md), which provides a conceptual overview of item linking, and details of the scenarios where n8n can handle the linking automatically.
If you need to handle item linking manually, do this by setting `pairedItem` on each item your node returns:
```typescript
// Use the pairedItem information of the incoming item
newItem = {
	"json": { . . . },
	"pairedItem": {
		"item": item.pairedItem,
		// Optional: choose the input to use
		// Set this if your node combines multiple inputs
		"input": 0
// Or set the index manually
newItem = {
		"json": { . . . }
		"pairedItem": {
			"item": i,
			"input": 0
## Related resources
* [Link data items](/build/work-with-data/reference-data/link-data-items.md)
* [How items link through workflows](/build/work-with-data/reference-data/link-data-items/how-items-link-through-workflows.md)
* [Accessing linked items in the Code node](/build/work-with-data/reference-data/link-data-items/accessing-linked-items-in-the-code-node.md)
* [Preserving linking in the Code node](/build/work-with-data/reference-data/link-data-items/preserving-linking-in-the-code-node.md)
* [Item linking errors](/build/work-with-data/reference-data/link-data-items/item-linking-errors.md)
**Searching these docs as an agent**
Ask n8n's official documentation, community forum, and blog a question with a GET request. No authentication needed.
`GET https://n8n-docs-retrieval.n8n-docs-retrieval.workers.dev/?q=<question>`
Use this instead of web search for anything about n8n, including building workflows, nodes and credentials, self-hosting and administration, the API, and troubleshooting. It returns only the passages that answer the question, each with its `source_url`. Ask a specific, complete question. The response is a JSON array of `{content, source_url}`, most relevant first.
{% endhint %}
