> For the complete documentation index, see [llms.txt](https://docs.n8n.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.n8n.io/build/work-with-data/handle-special-data-types/work-with-dates-and-times.md).
# Work with dates and times
Use Luxon to work with date and time in n8n.
[Luxon](https://github.com/moment/luxon/) is a JavaScript library that makes it easier to work with date and time. For full details of how to use Luxon, refer to [Luxon's documentation](https://moment.github.io/luxon/#/?id=luxon).
n8n passes dates between nodes as strings, so you need to parse them. Luxon makes this easier.
{% hint style="info" %}
**Python support**
Luxon is a JavaScript library. The two convenience [variables](#get-the-current-datetime-or-date) created by n8n are available when using Python in the Code node, but their functionality is limited:
* You can't perform Luxon operations on these variables. For example, there is no Python equivalent for `$today.minus(...)`.
* The generic Luxon functionality, such as [Convert date string to Luxon](#convert-date-string-to-luxon), isn't available for Python users.
  {% endhint %}
## Date and time behavior in n8n <a href="#date-and-time-behavior-in-n8n" id="date-and-time-behavior-in-n8n"></a>
Be aware of the following:
* In a workflow, n8n converts dates and times to strings between nodes. Keep this in mind when doing arithmetic on dates and times from other nodes.
* Using Luxon's `DateTime()` is the recommended approach in n8n. Using vanilla JavaScript's `Date()` doesn't work with some n8n features. For example, it doesn't respect the [Workflow-specific Time Zone](https://docs.n8n.io/workflows/settings/#timezone).
* With vanilla JavaScript, you can convert a string to a date with `new Date('2019-06-23')`. In Luxon, you must use a function explicitly stating the format, such as `DateTime.fromISO('2019-06-23')` or `DateTime.fromFormat("23-06-2019", "dd-MM-yyyy")`.
## Setting the timezone in n8n <a href="#setting-the-timezone-in-n8n" id="setting-the-timezone-in-n8n"></a>
Luxon uses the n8n timezone. This value is either:
* Default: `America/New York`
* A custom timezone for your n8n instance, set using the `GENERIC_TIMEZONE` environment variable.
* A custom timezone for an individual workflow, configured in workflow settings.
## Common tasks <a href="#common-tasks" id="common-tasks"></a>
This section provides examples for some common operations. More examples, and detailed guidance, are available in [Luxon's own documentation](https://moment.github.io/luxon/#/?id=luxon).
### Get the current datetime or date <a href="#get-the-current-datetime-or-date" id="get-the-current-datetime-or-date"></a>
Use the `$now` and `$today` Luxon objects to get the current time or day:
* `now`: a Luxon object containing the current timestamp. Equivalent to `DateTime.now()`.
* `today`: a Luxon object containing the current timestamp, rounded down to the day. Equivalent to `DateTime.now().set({ hour: 0, minute: 0, second: 0, millisecond: 0 })`.
Note that these variables can return different time formats when cast as a string:
{% tabs %}
{% tab title="Expressions (JavaScript)" %}
```javascript
{{$now}}
// n8n displays the ISO formatted timestamp
// For example 2022-03-09T14:02:37.065+00:00
{{"Today's date is " + $now}}
// n8n displays "Today's date is <unix timestamp>"
// For example "Today's date is 1646834498755"
{% endtab %}
{% tab title="Code node (JavaScript)" %}
```javascript
$now
// n8n displays <ISO formatted timestamp>
// For example 2022-03-09T14:00:25.058+00:00
let rightNow = "Today's date is " + $now
{% endtab %}
{% tab title="Code node (Python)" %}
```python
_now
# n8n displays <ISO formatted timestamp>
# For example 2022-03-09T14:00:25.058+00:00
rightNow = "Today's date is " + str(_now)
# n8n displays "Today's date is <unix timestamp>"
# For example "Today's date is 1646834498755"
{% endtab %}
{% endtabs %}
n8n provides built-in convenience functions to support data transformation in expressions for dates. Refer to [Expression reference](https://docs.n8n.io/build/work-with-data/transform-data/expression-reference.md) for more information.
### Convert JavaScript dates to Luxon <a href="#convert-javascript-dates-to-luxon" id="convert-javascript-dates-to-luxon"></a>
To convert a native JavaScript date to a Luxon date:
* In expressions, use the `.toDateTime()` method. For example, `{{ (new Date()).toDateTime() }}`.
* In the Code node, use `DateTime.fromJSDate()`. For example, `let luxondate = DateTime.fromJSDate(new Date())`.
### Convert date string to Luxon <a href="#convert-date-string-to-luxon" id="convert-date-string-to-luxon"></a>
You can convert date strings and other date formats to a Luxon DateTime object. You can convert from standard formats and from arbitrary strings.
**A difference between Luxon DateTime and JavaScript Date**
{% endhint %}
#### If you have a date in a supported standard technical format: <a href="#if-you-have-a-date-in-a-supported-standard-technical-format" id="if-you-have-a-date-in-a-supported-standard-technical-format"></a>
Most dates use `fromISO()`. This creates a Luxon DateTime from an ISO 8601 string. For example:
{% tabs %}
```js
{{DateTime.fromISO('2019-06-23T00:00:00.00')}}
{% endtab %}
```js
let luxonDateTime = DateTime.fromISO('2019-06-23T00:00:00.00')
{% endtab %}
{% endtabs %}
Luxon's API documentation has more information on [fromISO](https://moment.github.io/luxon/api-docs/index.html#datetimefromiso).
Luxon provides functions to handle conversions for a range of formats. Refer to Luxon's guide to [Parsing technical formats](https://moment.github.io/luxon/#/parsing?id=parsing-technical-formats) for details.
#### If you have a date as a string that doesn't use a standard format: <a href="#if-you-have-a-date-as-a-string-that-doesnt-use-a-standard-format" id="if-you-have-a-date-as-a-string-that-doesnt-use-a-standard-format"></a>
Use Luxon's [Ad-hoc parsing](https://moment.github.io/luxon/#/parsing?id=ad-hoc-parsing). To do this, use the `fromFormat()` function, providing the string and a set of [tokens](https://moment.github.io/luxon/#/parsing?id=table-of-tokens) that describe the format.
For example, you have n8n's founding date, 23rd June 2019, formatted as `23-06-2019`. You want to turn this into a Luxon object:
{% tabs %}
```js
{{DateTime.fromFormat("23-06-2019", "dd-MM-yyyy")}}
{% endtab %}
```js
let newFormat = DateTime.fromFormat("23-06-2019", "dd-MM-yyyy")
{% endtab %}
{% endtabs %}
When using ad-hoc parsing, note Luxon's warning about [Limitations](https://moment.github.io/luxon/#/parsing?id=limitations). If you see unexpected results, try their [Debugging](https://moment.github.io/luxon/#/parsing?id=debugging) guide.
### Get n days from today <a href="#get-n-days-from-today" id="get-n-days-from-today"></a>
Get a number of days before or after today.
{% tabs %}
For example, you want to set a field to always show the date seven days before the current date.
In the expressions editor, enter:
```js
{{$today.minus({days: 7})}}
On the 23rd June 2019, this returns `[Object: "2019-06-16T00:00:00.000+00:00"]`.
This example uses n8n's custom variable `$today` for convenience. It's the equivalent of `DateTime.now().set({ hour: 0, minute: 0, second: 0, millisecond: 0 }).minus({days: 7})`.
{% endtab %}
For example, you want a variable containing the date seven days before the current date.
In the code editor, enter:
```js
let sevenDaysAgo = $today.minus({days: 7})
{% endtab %}
{% endtabs %}
For more detailed information and examples, refer to:
* Luxon's [guide to math](https://moment.github.io/luxon/#/math)
* Their API documentation on [DateTime plus](https://moment.github.io/luxon/api-docs/index.html#datetimeplus) and [DateTime minus](https://moment.github.io/luxon/api-docs/index.html#datetimeminus)
### Create human-readable dates <a href="#create-human-readable-dates" id="create-human-readable-dates"></a>
In [Get n days from today](#get-n-days-from-today), the example gets the date seven days before the current date, and returns it as `[Object: "yyyy-mm-dd-T00:00:00.000+00:00"]` (for expressions) or `yyyy-mm-dd-T00:00:00.000+00:00` (in the Code node). To make this more readable, you can use Luxon's formatting functions.
For example, you want the field containing the date to be formatted as DD/MM/YYYY, so that on the 23rd June 2019, it returns `23/06/2019`.
This expression gets the date seven days before today, and converts it to the DD/MM/YYYY format.
{% tabs %}
```js
{{$today.minus({days: 7}).toLocaleString()}}
{% endtab %}
```js
let readableSevenDaysAgo = $today.minus({days: 7}).toLocaleString()
{% endtab %}
{% endtabs %}
You can alter the format. For example:
{% tabs %}
```js
{{$today.minus({days: 7}).toLocaleString({month: 'long', day: 'numeric', year: 'numeric'})}}
On 23rd June 2019, this returns "16 June 2019".
{% endtab %}
```js
let readableSevenDaysAgo = $today.minus({days: 7}).toLocaleString({month: 'long', day: 'numeric', year: 'numeric'})
{% endtab %}
{% endtabs %}
Refer to Luxon's guide on [toLocaleString (strings for humans)](https://moment.github.io/luxon/#/formatting?id=tolocalestring-strings-for-humans) for more information.
### Get the time between two dates <a href="#get-the-time-between-two-dates" id="get-the-time-between-two-dates"></a>
To get the time between two dates, use Luxon's diffs feature. This subtracts one date from another and returns a duration.
For example, get the number of months between two dates:
{% tabs %}
```js
{{DateTime.fromISO('2019-06-23').diff(DateTime.fromISO('2019-05-23'), 'months').toObject()}}
This returns `[Object: {"months":1}]`.
{% endtab %}
```js
let monthsBetweenDates = DateTime.fromISO('2019-06-23').diff(DateTime.fromISO('2019-05-23'), 'months').toObject()
This returns `{"months":1}`.
{% endtab %}
{% endtabs %}
Refer to Luxon's [Diffs](https://moment.github.io/luxon/#/math?id=diffs) for more information.
### A longer example: How many days to Christmas? <a href="#a-longer-example-how-many-days-to-christmas" id="a-longer-example-how-many-days-to-christmas"></a>
This example brings together several Luxon features, uses JMESPath, and does some basic string manipulation.
The scenario: you want a countdown to 25th December. Every day, it should tell you the number of days remaining to Christmas. You don't want to update it for next year - it needs to seamlessly work for every year.
{% tabs %}
```js
{{"There are " + $today.diff(DateTime.fromISO($today.year + '-12-25'), 'days').toObject().days.toString().substring(1) + " days to Christmas!"}}
{% endtab %}
```js
let daysToChristmas = "There are " + $today.diff(DateTime.fromISO($today.year + '-12-25'), 'days').toObject().days.toString().substring(1) + " days to Christmas!";
{% endtab %}
{% endtabs %}
This outputs `"There are <number of days> days to Christmas!"`. For example, on 9th March, it outputs "There are 291 days to Christmas!".
A detailed explanation of what the code does:
* `{{` and `}}`: in the expressions version, these indicate the start and end of the expression. The Code node version doesn't need them.
* `"There are "`: a string.
* `+`: used to join two strings.
* `$today.diff()`: This is similar to the example in [Get the time between two dates](#get-the-time-between-two-dates), but it uses n8n's custom `$today` variable.
* `DateTime.fromISO($today.year + '-12-25'), 'days'`: this part gets the current year using `$today.year`, turns it into an ISO string along with the month and date, and then takes the whole ISO string and converts it to a Luxon DateTime data structure. It also tells Luxon that you want the duration in days.
* `toObject()` turns the result of diff() into a more usable object. At this point, the expression returns `[Object: {"days":-<number-of-days>}]`. For example, on 9th March, `[Object: {"days":-291}]`.
* `.days` uses JMESPath syntax to retrieve just the number of days from the object. For more information on using JMESPath with n8n, refer to our [JMESpath](https://docs.n8n.io/build/work-with-data/handle-special-data-types/query-json-data.md) documentation. This gives you the number of days to Christmas, as a negative number.
* `.toString().substring(1)` turns the number into a string and removes the `-`.
* `+ " days to Christmas!"`: another string, with a `+` to join it to the previous string.
## Related resources
* [Handle special data types](https://docs.n8n.io/build/work-with-data/handle-special-data-types.md)
* [Work with files and images](https://docs.n8n.io/build/work-with-data/handle-special-data-types/work-with-files-and-images.md)
* [Query JSON data](https://docs.n8n.io/build/work-with-data/handle-special-data-types/query-json-data.md)
