For the complete documentation index, see llms.txt. This page is also available as Markdown.
Add notes and documentation
Sticky notes let you annotate and comment on your workflows.
n8n recommends using sticky notes on template workflows to help other users understand your workflow.
A basic workflow with a sticky note attached
Create a sticky note
Sticky notes are a core node. To add a new sticky note:
  1. Open the nodes panel.
  2. Search for note.
  3. Click the Sticky Note node. n8n adds a new sticky note to the canvas.
Edit a sticky note
  1. Double-click the sticky note you want to edit.
  2. Write your note. This guide explains how to format your text with Markdown. n8n uses markdown-it, which implements the CommonMark specification.
  3. Click away from the note, or press Esc, to stop editing.
Change the color
To change the sticky note color:
  1. Hover over the sticky note.
  2. Select Change color Change Sticky Note color icon.
  3. Choose from seven preset colors, or click the rainbow gradient button to select a custom color.
Color selector showing preset colors and custom color button
Custom colors
Besides the seven preset colors, you can select any custom color for your sticky notes:
  1. Click the button with the rainbow gradient and plus icon.
  2. Use the color picker to select your desired color, or enter a hex color code (for example, #FF5733).
  3. Click Apply to set the color.
n8n automatically saves your last-used custom colors (up to eight) and displays them in the color picker for quick access.
Custom colors feature theme-aware borders that automatically adjust for optimal visibility in both light and dark modes.
Sticky note positioning
You can:
  • Drag a sticky note anywhere on the canvas.
  • Drag sticky notes behind nodes. You can use this to visually group nodes.
  • Resize sticky notes by hovering over the edge of the note and dragging to resize.
  • Change the color: select the Options menu Options icon to open the color selector.
Writing in Markdown
Sticky Notes support Markdown formatting. This section describes some common options.
For a more detailed guide, refer to CommonMark's help. n8n uses markdown-it, which implements the CommonMark specification.
Make images full width
You can force images to be 100% width of the sticky note by appending #full-width to the filename:
Embed a YouTube video
To display a YouTube video in a note, use the @[youtube](<video-id>) directive with the video's ID. For this to work, the video's creator must allow embedding.
For example:
To embed your own video, copy the above syntax, replacing ZCuL2e4zC_4 with your video ID. The YouTube video ID is the string that follows v= in the YouTube URL.
See Workflow components for other elements you can add to a workflow.
Last updated
Was this helpful?
