Skip to content
For the complete documentation index, see llms.txt. This page is also available as Markdown.
What agents do
One way to think of an agent is as a chain that knows how to make decisions. Where a chain follows a predetermined sequence of calls to different AI components, an agent uses a language model to determine which actions to take.
Agents are the part of AI that act as decision-makers. They can interact with other agents and tools. When you send a query to an agent, it tries to choose the best tools to use to answer. Agents adapt to your specific queries, as well as the prompts that configure their behavior.
Agents in n8n
n8n provides one Agent node, which can act as different types of agent depending on the settings you choose. Refer to the Agent node documentation for details on the available agent types.
When you execute a workflow containing an agent, the agent runs multiple times. For example, it may do an initial setup, followed by a run to call a tool, then another run to evaluate the tool response and respond to the user.
Last updated
Was this helpful?
