How tools work
In AI, 'tools' has a specific meaning. Tools act like addons that your AI can use to access extra context or resources.
Here are a couple of other ways of expressing it:
Tools are interfaces that an agent can use to interact with the world (source)
We can think of these tools as being almost like functions that your AI model can call (source)
AI tools in n8n
n8n provides built in nodes and a registry of MCP servers that you can connect to your AI agent as tools. Built-in nodes include popular services such as Wikipedia and SerpAPI. Apart from these, n8n provides three especially powerful tools:
Call n8n Workflow Tool: use this to load any n8n workflow as a tool.
Custom Code Tool: write code that your agent can run.
HTTP Request Tool: make calls to fetch a website or data from an API.
The next three examples highlight the Call n8n Workflow Tool:
You can also learn how to let AI dynamically specify parameters for tools with the $fromAI() function.
Related resources
Last updated
Was this helpful?
