Skip to content
For the complete documentation index, see llms.txt. This page is also available as Markdown.
How memory works
Memory is a key part of AI chat services. The memory keeps a history of previous messages, allowing for an ongoing conversation with the AI, rather than every interaction starting fresh.
AI memory in n8n
To add memory to your AI workflow you can use either:
If you need to do advanced AI memory management in your workflows, use the Chat Memory Manager node.
This node is useful when you:
  • Can't add a memory node directly.
  • Need to do more complex memory management, beyond what the memory nodes offer. For example, you can add this node to check the memory size of the Agent node's response, and reduce it if needed.
  • Want to inject messages to the AI that look like user messages, to give the AI more context.
Last updated
Was this helpful?
