> For the complete documentation index, see [llms.txt](https://docs.n8n.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.n8n.io/build/code-in-n8n/use-built-in-shortcuts/http-node.md).
# HTTP node
n8n provides these methods to make it easier to perform common tasks in expressions.
Variables for working with HTTP node requests and responses when using pagination.
Refer to [HTTP Request](https://docs.n8n.io/integrations/builtin/core-nodes/n8n-nodes-base.httprequest.md) for guidance on using the HTTP node, including configuring pagination.
Refer to [HTTP Request node cookbook | Pagination](https://docs.n8n.io/build/code-in-n8n/cookbook/http-request-node/pagination.md) for example pagination configurations.
{% hint style="info" %}
**HTTP node only**
These variables are for use in expressions in the HTTP node. You can't use them in other nodes.
{% endhint %}
| Variable     | Description        |
| `$pageCount` | The pagination count. Tracks how many pages the node has fetched.        |
| `$request`   | The request object sent by the HTTP node.        |
| `$response`  | The response object from the HTTP call. Includes `$response.body`, `$response.headers`, and `$response.statusCode`. The contents of `body` and `headers` depend on the data sent by the API. |
## Related resources
* [Use built-in shortcuts](https://docs.n8n.io/build/code-in-n8n/use-built-in-shortcuts.md)
* [JMESPath](https://docs.n8n.io/build/code-in-n8n/use-built-in-shortcuts/jmespath.md)
* [LangChain Code node](https://docs.n8n.io/build/code-in-n8n/use-built-in-shortcuts/langchain-code-node.md)
* [n8n metadata](https://docs.n8n.io/build/code-in-n8n/use-built-in-shortcuts/n8n-metadata.md)
